trying to clear a coupon session
Thread begun 2/09/2015 2:31 am by Jamie | Last modified 2/10/2015 9:07 am by Jason Byrnes | 4806 views | 14 replies |
Jamie
Hey Jason
In an ecart install I have set up the coupons system (as per the coupon series in the tutorial area). I want to clear the coupon code when the buyer returns to one of 2 pages (invoice_thanks.php and checkout_success.php). I have added <?php if(isset($_SESSION['PromoCode'])) unset($_SESSION['PromoCode']); ?> to both these pages below </html> but it isnt clearing the session and keeps adding the coupon discount if you go back into buy something.
Cheers
Jamie
where did you add that code on those pages? at line 1?
Make sure to start the session also:
@session_start();
Jamie
no, I added it at the bottom of each page below </html>
so should I move it to line 1 and adjust it with the above?
It should be ok at the bottom, but you will probably still need to include the session start line.
Jamie
hmmmm just tried it and still not clearing the session.... have attached the 2 files in case i have missed something obvious
Jamie
if it helps with context, these 2 files can be found in the root of the site I just gave you ftp deets for
are you sure PromoCode is the right session name?
add the following code to write the session contents:
<pre><?php var_dump($_SESISON); ?></pre>
this should show the correct name for the session.
if you need further assistance, I'll need to troubleshoot directly, see the private message section.
Jamie
i'm getting NULL whuch would explain why it isnt clearing - so begs the question, if PromoCode is being used to set the coupon, what have i not done that is not bringung the session to the thanks pages?
if you want to take a look, ftp details are attached
Hhat is the full URL when at the cart display page where you enter the session?
What is the full URL when you get to the page where you are trying to clear the session?
Jamie
see pm
