add to cart button The ID Column will not show.
Thread begun 2/08/2015 8:07 am by john70964 | Last modified 2/09/2015 12:06 pm by Jason Byrnes | 2244 views | 3 replies |
john70964
I am following the tutorial
Add a shopping cart II (eCommerce Series) on page
http://www.webassist.com/community/tutorials/view_tutorial.php?tutorial=Add-a-shopping-cart-II-eCommerce-Series&accesscheck=/community/tutorials/view_tutorial.php?tutorial=Add-a-shopping-cart-II-eCommerce-Series
When I get to the part to add the button
Click WebAssist > eCart > Add to Cart Button.
Click on Look up item ID from recordset.
Set the Recordset to WADAproducts.
I tried to open the recordset and I get an error as shown in the attached image. I noticed the Recordset name in the picture I checked and confirm the name is WADAproducts
Can you see what may be going wrong please?
Many thanks
John
double check that the local testing server is started. it should like the local testing server has not been started.
if you try to preview the results page in a browser using the localhost address, does it preview correctly?
john70964
Well I dont know what happened Jason but the WADAproducts showed up in the wizard straight away.
Must be your magic!
John
you're welcome.
