error
Thread begun 2/07/2015 11:10 am by QuiruNet | Last modified 2/20/2015 8:42 am by Jason Byrnes | 4156 views | 9 replies |
QuiruNet
error
can you help me with that...all is ok, but it does not let me continue to install
QuiruNet
ftp access
looks like the diagnostic is failing because the SimpleXML extensions is not enabled in the php server.
you should contact the host to have them enable the SimpleXML extension for you.
QuiruNet
info
I spoke with the host and them enable de SimpleXML, but still the same error:
ERROR: ALL of the atributes below neew to check out before you can proceed to the next step. All atributes are in green.
when i look at the diagnostic page it is showing an issue with session management.
There is a problem with session management on your server. Contact your hosting provider to fix the problem. For more information, please refer to the PHP manual.
most likely a bad path for the session.save_path in the php.ini file.
QuiruNet
error
the host did that you told me, but it still wit me the same error.
Must upload it again?
No, uploading again is not needed.
using:
<?php var_dump($_SESSION); ?>
it is showing that the cURL connection to the web assist server is not being made. It looks like the host is blocking cURL requests to the web assist.com server. this connection is needed for activation. the host will need to enable cURL to make connections to the web assist server.
QuiruNet
host
Hi, jason i change the hosting and now its working, i have a question, i had over 7000 users, which is the best way to put the email settings, max emails, email every.....etc...
can you help my with that. Thanks
it really depends on your hosts limits. every host is different.
you should find out from the host what there mailing limits are and adjust the mail timings to accommodate.
