Is this easy to do ?
Thread begun 2/07/2015 4:56 am by J7HNW | Last modified 2/09/2015 10:55 am by J7HNW | 1408 views | 2 replies |
J7HNW
I have a site still running on ASP built with E cart . I want to be able to add one of 4 new Carriage
Charges for home deliveries ( So I guess these go under Shipping Charges )
The site works as follows
First you add an item to the cart here ( for example )
http://www.rosewoodfurniture.co.uk/rosewood-furniture-cartpay.asp/product/ff7318p-ming-style-curio-cabinet
You are then directed to see your cart contents here
http://www.rosewoodfurniture.co.uk/rosewood-furniture-uk-cartnew.asp
I would like to be able to add a LINK on this page to a new page I have made ( below ) where clients
can then select a White Glove home delivery at a SET price to the cart
http://www.rosewoodfurniture.co.uk/rosewood-furniture-white-glove-delivery.htm
Options are
1. Zone 1 2 3 Uninsured Home Delivery - This will add a value of £108 to the Cart
2. Zone 4 , 5 Uninsured Home Delivery - This will add a value of £144 to the Cart
3. Zone 1 2 3 Insured Home Delivery - This will add a value of £145.20 to the Cart
4. Zone 4 , 5 Insured Home Delivery - This will add a value of £181.20 to the Cart
I really dont want to have to break open the cart as I dont have the old version of E cart installed.
I just need some code to add to each of the 4 buttons which will allow the user to Add one of these 4 fixed
amounts of money to the shopping cart under shipping charges
What is the string of code I need please to add one of these Static Amounts to my Cart after the product
has been added
Hope you can help
Thanks in anticipation
John
This is not a very simple addition to your cart, you first need to save the selection to a session variable, then create a rule for each scenario, to set the shipping rate.
there is not a simple one line fix for this.
We could help you in adding the code to the cart object through a premiere support appointment:
http://www.webassist.com/premier_request.php
J7HNW
Hi JAson
Thanks - but I have found my own solution using spare fields
Please close the ticket
Thank you for your help
John
