html editor update page
Thread begun 2/05/2015 4:19 pm by Kumel | Last modified 2/17/2015 11:52 am by Kumel | 5122 views | 18 replies |
Kumel
i m facing this problem every html editor i added.
i have added html editor on insert & update pages.
Insert seems to work fine, but not update page.
When certain things are added like alignment, table width, img width or any custom styling on INSERT page it seems to work fine & displays fine on detail page. but as i go to update page things appear different img alignment, img alt, text alignment, table width height & etc are not the same. it comes to default settings. (no styling)
insert & update files are attached.
Regards
Kumel
pv msg
see PM
Kumel
pm.
on the update page, the value for the HTML Editor is set to convert " to &quote;
$CKEditor_initialValue = "".(str_replace('"', '"', $row_WADAproducts['ProductLongDesc'])) ."";
i removed the str_replace to fix the problem:
$CKEditor_initialValue = "".$row_WADAproducts['ProductLongDesc'] ."";
Kumel
what about bullet points? its not appearing.
in your style sheet:
http://www.lotomaster.in/en/css/style.css
you are suppressing the list style setting it to none which doesn't show bulet points:
ul li {
color: #494743;
font-size: 18px;
font-weight: 300;
line-height: 31px;
list-style: outside none none;
Kumel
same file on my local server bullet points appear :(
i can't troubleshoot your local computer, only the live site
but like i said, they are being suppressed by the css.
