Updated server to PHP 5.4 and updated WAUE code - now getting error: Strict Standards: Non-static method Mail::factory()
Thread begun 2/04/2015 2:31 pm by markhaynes75235 | Last modified 2/05/2015 3:20 pm by markhaynes75235 | 1608 views | 2 replies |
markhaynes75235
I've upgraded my server to PHP 5.4, and started testing my pages that use DataBridge features to insert data and send emails using WAUE. Though the insert and email work, I get the following errors:
Strict Standards: Non-static method Mail::factory() should not be called statically in /home/content/17/9433817/html/abilityconnectiontexas/webassist/email/PEAR_Mail_using_SMTP_php.php on line 190
Warning: Cannot modify header information - headers already sent by (output started at /home/content/17/9433817/html/abilityconnectiontexas/webassist/email/PEAR_Mail_using_SMTP_php.php:190) in /home/content/17/9433817/html/abilityconnectiontexas/volunteersignup.php on line 176
Line 190 of PEAR_Mail_using_SMTP_php.php is:
$theMailer =& Mail::factory('smtp', $paramArray);
Line 176 of volunteersignup.php is the WAUE redirect to load the confirm page:
header("Location: ".$GoToPage);
where the value for $GoToPage is set to the confirm page. I've attached the PEAR_Mail_using_SMTP_php.php and the volunteersignup.php for you to have a look.
I've uploaded all of the files that were changed when I updated the WAUE code:
mailformatting_php.php
waue_****.php
as well as the two attached pages.
Thanks as always for your help!
That is just a warning and won't prevent the page from working.
You can prevent ignorable errors from showing on your page by adjusting the php.ini error reporting setting to E_ALL & ~E_STRICT and they will magically disappear
You can probably fix it on the page by using the @ symbol which prevents displaying error messages on a single line like:
$theMailer =& @Mail::factory('smtp', $paramArray);
markhaynes75235
Thanks Ray!
I was able to find the line in the Mail.php file on the server where I made the following change:
function &factory($driver, params = array())
to
static function &factory($driver, params = array())
It's amazing what you can figure out at 2:00 in the morning! ;~}
Sorry I did not post this earlier - and thanks for being a great mentor.
