spry validation not working
Thread begun 2/04/2015 11:14 am by Kumel | Last modified 2/09/2015 12:42 pm by Jason Byrnes | 6501 views | 13 replies |
Kumel
i had created registration form using securityassist.
then i upgraded to data bridge just a day back now my spryvalidation doesnt seem to work.
errors are not hidden.
when browser's cache is cleared then error of form field are not shown & if i click register then page refreshes & displays error
( none of the form field were entered - just for testing)
Can anyone help me out with that?
files attached with spry folder
It sounds like the spry css isn't getting loaded. Do you have a url where I can view the problem live? I have a feeling it may not be an issue with the code but what files were uploaded and their locations.
Kumel
You can view them here: http://www.showoffgallery.in/registration.php
if u click register button then page refreshes & shows error for fields.
Spry validation has been deprecated and abandoned by Adobe.
Data Bridge replaces spry validation with JQuery validation.
I would recommend recreating the registration pages suing Data Bridge to have the spry validation replaced with JQuery validation. Spry is no longer being supported by Adobe.
Kumel
ok i created all new securityassist pages. how can we change the show if validation style?
& when i open new-userupdate page says no records found.
go to WebAssist -> Forms -> JQuery. on the first tab you can set the style for the validation errors.
on the users update page, how is the recordset configured?
if you add the following code in the body, what does it show:
<?php @var_dump($_SESSION); ?>
Kumel
webassist - forms-> jquery? nothing as such.
users update page:
array(5) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["WAVT_newlogin_Errors"]=> string(0) "" ["UserID"]=> string(1) "2" ["UserEmail"]=> string(18) "kumel619@gmail.com" }
the session being created by the login is UserID
on the user update page, the recordset is sett filter using the session:
$_SESSION["SecurityAssist_UserID"]
change that to:
$_SESSION["UserID"]
Kumel
when submitting form i get errors as attached.
Even when everything is filled up.
it;s probably the unique validation error. there is most likely already a record with that email address in the system
