Need Help Resolving Dual WA_Globals.php files
Thread begun 8/27/2009 7:28 pm by lyn212943 | Last modified 8/28/2009 1:23 pm by Jason Byrnes | 3368 views | 3 replies |
lyn212943
I'm trying to use the Contact Form solution pack AND the User Registration pack but each solution pack uses a different WA_Globals.php file.
I can't put both files inside the WA_Globals sub-directory or one file will overwrite the other and both WA_Globals.php files are needed to operate the 2 different forms.
the simplest way to accomplish this is to have a folder for the contact form file:
contactForm/
and another folder for the User Registration Files:
userRegistration/
and place the files for each in their respective folders.
other wise, you would need to rename each WA_Globals file, for example:
WA_Globals_CF.php
WA_Globals_UR.php
and change the require once code to point to the correct one on each page:
<?php require_once( "WA_Globals/WA_Globals_CF.php" ); ?>
<?php require_once( "WA_Globals/WA_Globals_UR.php" ); ?>
lyn212943
Thank you Jason
Thanks so much, Jason. Have a great weekend.
You're welcome, you have a great weekend as well.
