Continues Error after updating to data bridge
Thread begun 2/04/2015 1:55 am by Kumel | Last modified 2/05/2015 9:11 am by Jason Byrnes | 3025 views | 7 replies |
Kumel
Receiving error continues after successful update.
Kumel
another error. unable to work. errors overloading.
I have latest version on flash yet in dataassist page preview section says : update flash.
My eCart Version is 5.0.7
Kumel
i removed all extensions & cleared macfile from config. now i installed ecart & dataBridge.
i can not see any errors now. but databridge isn't visible when i try to open anything from databridge.
I also did reset workspacelayout
Kumel
once again i removed all extensions and then installed them. again i m getting above ecart errors repeatedly
Make sure you don't install the old eCart version after your DataBridge installation.
This error appears to be a result of overwriting newer files that are installed with databridge with older files from eCart 5.
I think if you just uninstall and reinstall Databridge it should correct this problem.
Kumel
Nope. yet the same. :(
Not sure what the problem is.
Any solution?
Problem arise only where ecart is present.
Kumel
another new error along with others as earlier.
this i a conflict between the older version of eCart and the newer Data Bridge
install eCart first, then start DW and close it again, then install Data Bridge.
