Need toolbargroupdefinitions table
Thread begun 2/03/2015 8:35 am by Jared Lui | Last modified 2/03/2015 9:14 am by Jared Lui | 633 views | 0 replies |
Jared Lui
UPDATE! NO NEED TO REPLY - Found the DB file in the install folder.
In short - I need a copy of the default toolbargroupdefinitions table.
The reason - When Power CMS was installing on a fresh site and blank database it created the tables part way through, then when part way through the wizard it said it could not continue because pcms2_contenthistory, pcms2_contents, pcms2_usergroups and pcms2_users tables already existed and needed to be removed to continue.
Did that and then it said the pcms2_toolbargroupdefinitions need to be removed too.
Did that and it continued to install.
Then it got a warning that it could not find the connection file. Looked and it did not copy over the connection directory and files. So uploaded them and connected fine into the admin.
However, trying to access the site am not getting "Table 'aledoleg_site.pcms2_toolbargroupdefinitions' doesn't exist"
Sure enough the table is missing (never recreated).
I know I should start over and re-install and I will once I have time to test. But in the interim, does anyone (Jason) have a default copy they can send my way.
Thanks.
