rearranging records in backend cms via the use of and up/down arrow
Thread begun 2/02/2015 7:57 am by Christopher West | Last modified 2/05/2015 8:34 am by Jamie | 2431 views | 5 replies |
Hi I wondered if you could help adjusting some code to work with MySQLi and WebAssist code. Basically I had a restaurant menu and in the backend i want to allow the client to change the order of the various menu items (so I am populating the field itemorderid).The client will be able to reorder the menu items via a small up and down arrow icon link that will be show up on every record on the admin page.
So what I will be doing is coding the backend so that when the client clicks on the up or down arrow icon it will append the url with a url variable that I can then use in an IF statement to check with.
I found some php code, I just need to adjust it to work with mysqi updates:
if (isset($_GET['move']) )
    if ( $_GET['move'] == "up")
         $connector->query("UPDATE `TopTips` SET `order` = `order` - 1 WHERE `id` = " . $_GET['lastid']);
        $connector->query("UPDATE `TopTips` SET `order` = `order` + 1 WHERE `id` = " . $_GET['id']);
     else if ( $_GET['move'] == "down")
        $connector->query("UPDATE `TopTips` SET `order` = `order` + 1 WHERE `order` = " . $_GET['nextid']);
        $connector->query("UPDATE `TopTips` SET `order` = `order` - 1 WHERE `id` = " . $_GET['id']);
WE would be able to help you with this custom coding through a premiere support appoint:
http://webassist.com/premier_request.php
I've got a jQuery/Ajax/PHP draggable solution working so will create a tutorial for it so that others can benefit from it :)
dlovas275157
Christopher,
I'm interested in this tutorial. Please post back once you have it completed. Appreciate it.
-DL
Thanks for that Chris, I'm sure others will appreciate it.
Jamie
+1 from me as well :)
