binding select list populated dynamically First Name Last Name
Thread begun 2/02/2015 7:24 am by JBWebWorks | Last modified 2/03/2015 9:10 am by Jason Byrnes | 5275 views | 9 replies |
JBWebWorks
I think this is treated as an array but not sure.
My select list
<option value="<?php echo $row_rs_members['First Name']?> <?php echo $row_rs_members['Last Name']?>" <?php if(in_array("['First Name']", $selected)) echo("selected=\"selected\""); ?>><?php echo $row_rs_members['First Name']?> <?php echo $row_rs_members['Last Name']?></option>
Not sure how to write the if statement?
double check the name of the select list. if the name use [] at the end:
selectName[]
then it is an array
the if statement format would be:
if(in_array($row_rs_members['First Name'], $selected)
JBWebWorks
Put this at top of page
if($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
Put this before the form
<?php $selected = explode(", ", ValidatedField("index_500","player1")); ?>
and this is the form
<form id="form1" name="form1" method="post" action="">
<label for="player1"><strong>Your Name:</strong></label>
<select name="player1[]" id="player1">
<option value="" selected="selected">Select From Dropdown</option>
do {
<option value="<?php echo $row_rs_members['First Name']?> <?php echo $row_rs_members['Last Name']?>" <?php if(in_array($row_rs_members['First Name'], $selected)) echo("selected=\"selected\""); ?>><?php echo $row_rs_members['First Name']?> <?php echo $row_rs_members['Last Name']?></option>
} while ($row_rs_members = mysql_fetch_assoc($rs_members));
$rows = mysql_num_rows($rs_members);
if($rows > 0) {
mysql_data_seek($rs_members, 0);
$row_rs_members = mysql_fetch_assoc($rs_members);
</select>
if (ValidatedField('index_500','index_500')) {
if ((strpos((",".ValidatedField("index_500","index_500").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="stylered">Name required</span>
<?php //WAFV_Conditional index.php index_500(1:)
<br />
<br />
<label for="tee1"><strong>Your Tee Choice:</strong></label>
<select name="tee1" id="tee1">
<option value="" selected="selected" <?php if (!(strcmp("", (ValidatedField("index_500","tee1"))))) {echo "selected=\"selected\"";} ?>>Select Your Tee</option>
<option value="Gold" <?php if (!(strcmp("Gold", (ValidatedField("index_500","tee1"))))) {echo "selected=\"selected\"";} ?>>Gold</option>
<option value="White" <?php if (!(strcmp("White", (ValidatedField("index_500","tee1"))))) {echo "selected=\"selected\"";} ?>>White</option>
<option value="Blue" <?php if (!(strcmp("Blue", (ValidatedField("index_500","tee1"))))) {echo "selected=\"selected\"";} ?>>Blue</option>
<option value="Black" <?php if (!(strcmp("Black", (ValidatedField("index_500","tee1"))))) {echo "selected=\"selected\"";} ?>>Black</option>
</select>
if ((strpos((",".ValidatedField("index_500","index_500").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="stylered">Tee Required</span>
<?php //WAFV_Conditional index.php index_500(2:)
<br />
<br />
<label for="pairing1"><strong>Pairing Request:</strong></label>
<textarea name="pairing1" id="pairing1" cols="45" rows="5"><?php echo(ValidatedField("index_500","pairing1")) ?></textarea>
<br />
<br />
<input type="submit" name="submit2" id="submit2" value="Submit Saturday Signup" />
</p>
</form>
It seems that the if in array statement would have to include both First Name and Last Name, but not sure?
Currently the validation to require a choice for player1 works but does not bind the choice upon validation failed.
ok, so if you need the first and last names, the format of the if statement would be:
if(in_array($row_rs_members['First Name']." ".$row_rs_members['Last Name'], $selected)
JBWebWorks
Thanks Jason. I wasn't sure how to write the if statement. Works now.
One other question
I know that adding the progress bar to a form creates a bad jquery-blockui-formprocessing.js
Is there a way I can permanently correct that so that the jquery-blockui-formprocessing.js that is created is good?
if you have the most recent version of Data bridge, there should not be a problem with the jquery-blockui-formprocessing.js
JBWebWorks
I downloaded the newest version of Data Bridge
Installed it but i had not removed the extensions that i had installed that are incorporated in Data Bridge
So i went back and removed Data Bridge and the other extensions. I inadvertently removed validation toolkit. Yes, i kinda messed up.
Now i'm getting this error
that error looks like the web assist installer did not run to complete the installation.
After installing the extension in the extension manager, open Dreamweaver, this should start the WebAssist installer. If the WebAssist installer does not start, you may need to open a PHP page to force it to launch.
after the WebAssist installer completes, make sure to restart Dreamweaver.
JBWebWorks
The problem I caused is I installed Data Bridge1.21 without removing the individual extensions that are bundled with Data Bridge. Then realizing my problem I removed the extensions and by mistake removed Validation Toolkit 2.35.
Now i have removed the bundled products and reinstalled Data Bridge and Validation Toolkit which stopped the error I was having.
But when I apply validation to a form that i build, the validation is the old version, i.e.
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
and not
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
How do i fix this?
Got it working now by uninstalling Validation Tool Kit and reinstalling Data Bridge.
There are still some code bugs in the validation show if, but I can work around that.
Validation toolkit is a part of Data Bridge, so it should not be installed along side Data Bridge.
