MySqli details about error
Thread begun 1/30/2015 9:39 am by marko438831 | Last modified 3/19/2015 9:27 am by Jason Byrnes | 3298 views | 5 replies |
marko438831
If i make mistake in SQL syntax, then i get simple error message: "Error in SQL syntax".
How i can get more detailed error message?
I tried "mysqli_error($connection)" but no success.
you may be able to see the SQL causing the error using:
<?php echo $recordsetName->debugSQL(); ?>
where recordsetName is the name of the recordset, but it really depends on the severity of the syntax error
Chad
Is there a debug command for insert and update statements as well? I have a query that isn't updating a table properly and want to see where the issue may be.
Thanks,
Chad
in the webassist/mysqli/queryobj.php file, change:
$this->Debug = false;
$this->Debug = true;
Nico
webassist/mysqli/queryobj.php does not exist
I only have rsobj.php inside the webassist/mysqli/ folder, and there I cant locate $this->Debug = false;
Using latest version of DW CC
the queryobj.php file is for insert/delete/update behaviors.
if you don't have that file you are not working with an insert, update or delate behavior.
if you want to see the compiles SQL for a recordset, use:
where recordsetName is the name of the recordset.
