Powergallery
Thread begun 1/30/2015 8:27 am by rob294118 | Last modified 2/02/2015 11:30 am by Jason Byrnes | 4989 views | 15 replies |
rob294118
Powergallery
My galleries are not load all of a sudden. Website: www.insightskarate.com
rob294118
See PM.
few issues:
1) There was a permissions error in the gallery folder, some of the files in subfolders keep getting the permissions set to 200, I had to change the persimmons to 755, but after a while they get set back. check with the host to determine why the permissions are being charged.
2) there are a number of gallery files that have not been uploaded to the server that is causing an issue, as an example:
http://www.karatemilford.com/js/mootools-core.js
3) your page has another slider script on tit that is causing a conflict:
TypeError: $(...).easySlider is not a function
$("#slider").easySlider({
4) you had hand edited the Connections/powergallery.php file and changed all the <powergallery> references to localhost, this was braking the connection, i had to change that back.
rob294118
se pm
it's not working because of the missing files issue i pointed out and the persimmons issue
for some reason, you server keeps reverting the permissions to 200, you will need to determine why the server is doing it.
I can change the permission to 755, and it shows for a moment, then goes back to the 200 permission and does not show.
also, the missing JS files are an issue. I ended up having to also correct the database connection file and upload a few other files.
rob294118
Which folders are 200? I uploaded the js files.
files under the galleries subdirectory are getting set to 200
for example:
http://www.karatemilford.com/PowerGallery/galleries/ribbon_fullsize/index.php
rob294118
I fixed the permissions and it still doesn't work.
see PM
