ecart shipping charges
Thread begun 1/29/2015 1:35 pm by Kumel | Last modified 2/03/2015 9:13 am by Jason Byrnes | 4145 views | 9 replies |
Kumel
I wanna know about how to add shipping charges from by choosing checkbox as attached.
Can these are my codes for shipping charges:
<p>
<label>
<input name="RadioGroup1" type="radio" id="RadioGroup1_0" value="0" checked>
</label>
<label for="RadioGroup1_0" class="checkbox">Standard Delivery <span>FREE <abbr class="sep">|</abbr> Delivery in 2 to 4 Business Days</span></label>
<br>
<label>
<input type="radio" name="RadioGroup1" value="100" id="RadioGroup1_1">
</label>
<label for="RadioGroup1_1" class="checkbox">Express Delivery <span>Rs. 100 <span class="sep">|</span> Delivery in 1 to 2 Business Days</span></label>
<br>
</p>
one has 0 value other has 100.
0 & 100 are shipping charges.
So i want it to reflect as shipping charges on confirm page. How do we do this?
FYI:
Attached files are from checkout.php page only.
Regards
use the set session value behavior to save the shipping selection to a session variable.
Create a shipping rule for express delivery and use the based on session variable trigger so it only applied the rule if the session uses the express shipping value.
Kumel
ok i got no results.
*use the set session value behavior to save the shipping selection to a session variable.
-i did this. screen shot attached.
*Create a shipping rule for express delivery and use the based on session variable trigger so it only applied the rule if the session uses the express shipping value.
- NOT SURE IF I DID IT RIGHT. please correct me if i m wrong. ( another screenshot attached)
These are the codes:
<label>
</label>
<br>
<label>
</label>
php pages also attached.
checkout-billing-details.php is checkout page.
checkout-delivery.php is confirm.php page.
Regards
1) on the checkout-billing-details.php page, the action of the form is to post to the checkout-delivery.php page:
<form name="ecart_checkout_form" action="checkout-delivery.php" method="post">
Rule # 1 when working with forms:
All Form Processing must occur on the action page.
this means: you need to apply the behavior to set the session to the action (checkout-delivery.php) page.
2) in your shipping rule, you have the trigger:
Number of Items == 0
this will cause the shipping to apply only if the cart is empty, change that to > 0
Kumel
yet not working.
i think i went wrong in ecart shipping rule.
Attached.
Shipping charges appears but price is $productprice+$100.
I just want seperate $100 added as shipping charges.
Regards
Kumel
looks like i got it now :)
flat rate :)
Regards
Kumel
well now it works fine. had a small doubt now my checkout_success.php page. It is empty, so how do we show some results from confirm.php page?
Like Order ID:
Order Amount:
Like creating in a Bill Format all data from previous page ie confirm.php
Private Message..
Use the session variable bindings on the success page to display the order number and other information.
Kumel
attached is a success page. i can not find anything related to order on session binding.
the store order summary is saving the order ID to a session named:
eCart1_OrderID
<?php echo($_SESSION['eCart1_OrderID']); ?>
