RuleLooperName("Shipping") not saving to eCart Store Summary in Database properly?
Thread begun 1/29/2015 1:00 pm by Nathon Jones Web Design | Last modified 2/11/2015 11:16 am by Jason Byrnes | 3341 views | 6 replies |
On confirm.php we are saving the name of the shipping rule to one of the fields (LEDOrderShippingType) in our Order table via the eCart Store Summary in Database behaviour.
We have noticed that what it actually does is store the same thing every time, no matter what shipping rule is used. It is always:
Standard Delivery (Under £60.00/Under 1kg)
Thankfully the shipping cost is correct however customers have started to query this and, inspecting the code, I can't work out what it's not updating correctly. I attach confirm.php and provide FTP details privately below.
Thank you.
NJ
FTP...
I think you'll need to code a loop through the shipping rules to see which ones aren't 0, then create a session wit the rule names.
for example on a cart named eCart1:
$_SESSION['shipName'] = "";
if (!$eCart1->Rules_EOF("Shipping")) {
while (!$eCart1->Rules_EOF("Shipping")) {
if ($eCart1->RuleLooperValue("Shipping") > 0) {
$_SESSION['shipName'] .= "".$eCart1->RuleLooperName("Shipping")." ";
$eCart1->Rules_MoveNext("Shipping");
$eCart1->Rules_MoveFirst("Shipping");
then on the bindings panel, clic the plus button, and select Session, name the new binding shipName and use that binding in the store order summary
Have implemented that and now nothing is being saved to eCart Store Summary In Database. Page attached. Hope you can help. Thank you.
NJ
The site is www.ledwarehouseuk.com and the FTP details are provided above.
Thank you.
NJ
i thank the pound symbol in the rule name was causing the problem.
I changed:
$_SESSION['shipName'] .= "".$LEDCart->RuleLooperName("Shipping")." ";
$_SESSION['shipName'] .= "".htmlentities($LEDCart->RuleLooperName("Shipping"))." ";
I think that should fix it.
