form validations and redirect
Thread begun 1/29/2015 10:06 am by Jamie | Last modified 1/29/2015 10:59 am by Jason Byrnes | 962 views | 1 replies |
Jamie
Hi Jason
Am having a bit of a play with some responsive stuff and putting together a business listing (using a 3rd party complete script) - http://www.dorsetdirectory.co.uk
I have added a 'get in touch' button (http://prntscr.com/5ykatm) which opens a modal with a contact form in it. The form itself works and submits fine but I have a couple of issues.
First one is that if you try to send and validations fail, if you then close the modal itself the validations remain on the page - http://prntscr.com/5yi0uh
The other problem is that I am trying to add a 'thanks' message after successful submit - either in the modal itself (which I cant get to work) or, failing that, putting the message text in the area shown here http://prntscr.com/5yi0nf but I cant figure out how to do that either.
Have added the page itself plus FTP details in the PM should you need them
Cheers
Jamie
using form validations with a modal window is going to take custom coding, the validation would need to be done through ajax. we can help you implement this in a premiere support appointment:
http://www.webassist.com/premier_request.php
