I am using the mysqli login and even though I've set the success redirect to newrecord.php, it goes back to the last page I was logged into modifypage.php?eid=xx.
Thread begun 1/28/2015 2:57 pm by dionysus224892 | Last modified 1/30/2015 11:41 am by Jason Byrnes | 3926 views | 5 replies |
dionysus224892
I've added the details because I expressly want that page to load after login—I don't want any previous information saved in the session. How can I ensure the page I want loading?
make note of the name you assigned the login, the you can add code to the login page at line 1 to unset the redirect session that is created.
for example if the login is named MyLogin:
@session_start();
if(isset($_SESSION['WA_FAIL_MyLogin'])) unset($_SESSION['WA_FAIL_MyLogin']);
dionysus224892
Hi there Jason and thanks for responding
I use the login name "user" and I inserted the code you sent as shown here :
<?php require_once('Connections/ehs.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
@session_start();
if(isset($_SESSION['user'])) unset($_SESSION['user']);
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$Authenticate = new WA_MySQLi_Auth($ehs);
$Authenticate->Action = "authenticate";
$Authenticate->Name = "user";
But problem is still happening. And not only that, but it logs back with a doubled query string.
For example :
I'm at modifypage.php?id=55 and login expires or I logout.
When I log in again, instead of going to newpage.php, it goes to modifypage.php?id=55&id=55 which causes a SQL syntax error.
Not sure why when I"m using the extension and not messing around with it.
QUESTION : do I reference $_SESSION['user'} our #_SESSION['WA_FAIL_user']?
should be:
if(isset($_SESSION['WA_FAIL_ user'])) unset($_SESSION['WA_FAIL_ user']);
dionysus224892
Thanks you! It seems to work great now. I appreciate your help!
you're welcome.
