Paginated results pages not showing any results on p2!
Thread begun 1/28/2015 2:43 pm by Mags | Last modified 1/30/2015 6:28 am by Jason Byrnes | 3205 views | 7 replies |
Mags
I've got a paginated results page which shows 20 records per page. It shows the records correctly on the first page but when you go to the second page it says "No Results Found". I had to do a quick fix for our client by displaying all the records on the page instead but would like to get the pagination working again.
Mags
Thanks Jason, see below.
see PM
Mags
See PM.
the code to generate the pagination links:
$queryString_WADAclients = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAclients") == false &&
stristr($param, "totalRows_WADAclients") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAclients = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAclients = sprintf("&totalRows_WADAclients=%d%s", $totalRows_WADAclients, $queryString_WADAclients);
was above the recordset, it needed to be moved below the recordset.
Mags
Thanks SO much Jason, you saved my life!!
you're welcome.
