Data Assist 2.0.5 and PHP 5.3.0
Thread begun 8/27/2009 3:58 pm by sandy170299 | Last modified 8/28/2009 9:29 am by Jason Byrnes | 4893 views | 4 replies |
sandy170299
I have just started using PHP with Data Assist and I'm running into some glitches. In my admin area, I am using an included header and footer file with each page's content.
<?php include("header.php"); ?>
...page content goes here...
<?php include("footer.php"); ?>
Whenever I insert or update a record, it saves the record, but instead of redirecting to the page it's supposed to redirect to, I get an error message that says, for example:
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\lentz\admin\articles_Insert.php:26) in C:\xampp\htdocs\lentz\admin\articles_Insert.php on line 57
The lines mentioned above is the insert script and I have no idea where to start to debug it.
This error occurs if there is any out put to the page before a header() or session_start() function.
The error reports:
So I would start looking around line 35 and line 26, Look for and echo() command, or blank space between code blocks like:
24- ...<phpcode>
25- ?>
26-
27- <?php
28- <more PHP code>...
that blank line at 26 above will cause a similar error. if you can spot the problem, compress you page in a zip archive and attach it to your replay and I will take a look.
sandy170299
Jason, I probably have things in the wrong order :) I'm attaching my page.
sandy170299
Jason, I think I found the problem. There was a blank line between the PHP blocks of code. I didn't realize it was so picky!
Yeah, PHP can be quite persnickety that way.
