retrieving a particular record from a database
Thread begun 1/27/2015 10:44 am by Christopher West | Last modified 1/27/2015 12:47 pm by Jason Byrnes | 4245 views | 7 replies |
Hi, been some time, and just have a quick question, I have a table in the database called 'sitesettings' which store generic information such as website email address, phone number, address, meta title tag and meta description.
the table is as follows:
$rsSiteSettings
= new WA_MySQLi_RS("rsSiteSettings",$sitedb,1);
$rsSiteSettings->setQuery("SELECT * FROM settings");
$rsSiteSettings->execute();
therefore the binding would be:
<?php echo($rsSiteSettings->getColumnVal("settingscontent")); ?>
However how could I use the above binding so that for example in my HTML head I want place this binding inbetween: <title></title>
database table is:
settingsid
settingselement
settingscontent
and the first record the data is:
element = title
content = some random title for seo title demonstration
I tried doing it as an IF statement but even though it works when I used it for the title tag in my html, it doesnt work for the description metatag (is as though the record isnt moving onto the next so the IF statement lookup doesnt become true:
if ("".($rsSiteSettings->getColumnVal("settingselement"))  ."" == "title") {  // WebAssist Show If
} // ("".($rsSiteSettings->getColumnVal("settingselement"))  ."" == "title")
Since I be using this database table to store quite a bit of information relating to the website, I be using this data quite a bit on the page so wondered if there is a shorthand approach when adding a record binding to my html?
Regards
Chris
to move the recordset pointer to the next record, you need to use the moveNext function:
$rsSiteSettings->moveNext();
ah ok. obviously if I have lots of data relating to the webpage stored in my table (for example lets say 100 records in the table) and I am displaying those 100 records in various places dotted around the webpage...doing 100 IF statements all over the place is quite messy...is there some kind of short hand approach to display this data?
it sounds like a messy table structure
instead of a different record for each piece, use different column and one record.
that way you could output the title as:
<?php echo($rsSiteSettings->getColumnVal("title")); ?>
and the meta description tag as:
<?php echo($rsSiteSettings->getColumnVal("meta_description")); ?>
etc... no need for if statements.
the problem with that approach is I be using the same type of approach for my main content....I have designed a one page website so on that one page is different sections (about us, booking, contact us etc)
So I wanted to store the data like so:
element
content
so the element is basically storing the location on the page (eg. about us, booking, contact us etc)
then you are going to have to use the messy 100 if statements approach.
Been speaking with Ray and he told me about a handy function inside MySQi so he gave me the solution to use that function. here is the workaround in case anyone else wants to find out how to store all different types of data in the same database table (this is particularly useful if you have a one page website with different sections (such as about us, services, blog, testimonials, contact us) and thus all share same layout, eg a section header, section content...
<?php $rsSiteSettings = new WA_MySQLi_RS("rsSiteSettings",$sitedb,0);
$rsSiteSettings->execute();?>
Note: the 0 at the end of the first line is important so that it returns all rows.
and for my example I am stored for SEO purposes the title and description tag in my database table
(using element to store the location and content to store...um..the content)
<title><?php
$rsSiteSettings->moveFirst();
$rsSiteSettings->findRow('settingselement','title');
?></title>
<meta name="description" content="<?php
$rsSiteSettings->findRow('settingselement','description');
That's helpfull, I wasn't aware of the findRow() function...
Thanks for posting that.
