dynamically adding maps
Thread begun 1/22/2015 3:24 am by Jamie | Last modified 1/23/2015 8:55 am by Jason Byrnes | 1812 views | 3 replies |
Jamie
Hi Jason
Am having a play around with go,ogle maps and have managed to work out how to have one map with multiple pins (http://blandfordbusiness.co.uk/test.php) just got a couple of Q's
1. is there anyway to make the map view dynamically change its perspective to include all pins on first view? If you take a look at the above test map, you will see that you need to zoom out to take in a couple of extra pins...
2. related to #1 but is there anyway to center the map based on the furthest extent pins?
3. how to set the info window to not show without a pin being clicked - I have tried uncommenting //infowindow.open(map2,marker); but its still showing the window. if you take alook at this page to see what I mean:http://bit.ly/1E5mAN8
Cheers
Jamie
1) no, it's not possible to dynamically set the zoom level
2) The last record in the recordset will be the center point. aside from serving an order by to the recordset, that is the only way to controll where the map is centred
3) change isDefault code:
if (isDefault) {
setTimeout("google.maps.event.trigger(wagmp_map_2_obj.markers[" + wagmp_map_2_obj.markers.length + "], 'click')",1000);
//map2.setCenter(point);
if (isDefault) {
//setTimeout("google.maps.event.trigger(wagmp_map_2_obj.markers[" + wagmp_map_2_obj.markers.length + "], 'click')",1000);
Jamie
thanks Jason. How would you create a link to open the main google maps website and show the location link for that member?
the format for sending an address to the google site would be:
https://www.google.com/maps/place/760+West+Genesee+Street+Syracuse+NY+13204
http://gearside.com/easily-link-to-locations-and-directions-using-the-new-google-maps/
