delete multiple records with mysqli connection ?
Thread begun 1/21/2015 6:19 am by CraigR | Last modified 1/21/2015 9:28 am by Jason Byrnes | 1191 views | 1 replies |
CraigRBeta Tester
I want to delete all items from a stock list after a successful purchase, using the cart as a data source, just before the session values are cleared
I see two ways of doing this.
Loop through the cart and within that loop, delete each itemid in turn
Loop through the cart adding the item id's to a string or an array, and then using this as a criteria, delete all items at once, using something like DELETE FROM tblitems WHERE ItemID in ('array values').
Can this be done using a MySQli, server behavior ?
Yes, it can be done but will take hand coding to accomplish.
your first method:
is probably the easiest
create a cart loop, add the delete behavior in side the cart loop, and pass the cart ID as the itemID variable to delete.
