cart columns and grouping
Thread begun 1/20/2015 7:47 am by marsha431457 | Last modified 1/22/2015 12:16 pm by Jason Byrnes | 3406 views | 8 replies |
marsha431457
"group with previous column" button not displaying in Display Manager
eCart 6 does not have the Group with previous column anymore.
instead, you create a cart display column in the display manager, click t he lightning bolt next to Columns and select the Cart Columns to display.
marsha431457
there is no lightning bolt next to the columns in the eCart 6 Display Manager, there is an edit pencil. When I click that and add the 3 inscription entry columns the whole Inscription column disappears from the list of columns.
I had this working when I first uploaded and tested the page and the cart, but the price wasn't displaying correctly and I wanted to remove the 1 from Inscription1 in the top header of the column. After I edited the cart to fix that, it didn't work at all. After subsequent editing it is working fine in all other columns except for the Inscription and Logo choices, where I need to group them... at least I think that's what I need to do.
see http://bandofhonor.com/bracelets_aluminum.php
Ok, this is a bug in eCart, we will have a hot fix for this available later today to fix the problem, I will update this thread to let you know when it is available.
marsha431457
Thank you, been very frustrated and am on a deadline!
ok, eCart has been updated.
close DW, uninstall eCart 6 from the extension manager, then install it again. when you open DW, this should start the WebAssist installer. If the WebAssist installer does not start, you may need to open a PHP page to force it to launch.
after the WebAssist installer completes, make sure to restart Dreamweaver.
marsha431457
and I don't need to download anything?
Oh I see now, it is downloading and installing. Forgot about that!
marsha431457
1. The fix worked and my cart is displaying correctly except for one thing. In the logo column they need to be able to choose a Left logo AND a Right logo OR a logo for both sides how do I set it so that they can pick 1 from each of left and right?
2. Also I put "None" as a choice in all 3 list value drop downs but maybe it would be better to add another column item ("No logos")? Or maybe a radio button to the left of the "Logo and Placement" copy that chooses to include a logo, and THEN they choose from the logo options? Is that possible?
OK, new info: I have found the problem with picking one left and one right logo and solved. Minor code issue due to changing things around. But question #2 still is a question.
I think what i would do is have only 2 lists:
Left Logo | Right Logo
leave the no logo option in both.
If they want the same logo on both right and left, they select the same logo in both lists.
If you are proficient with javascript, you could add a checkbook for same log on both sides, and create an onchange event to set the right logo the same as the left, but that would take unsupported custom coding.
