MySQLi update
Thread begun 1/19/2015 10:49 am by Poj | Last modified 1/20/2015 10:30 am by Jason Byrnes | 4697 views | 9 replies |
Poj
MySQLi update
I corrects and updates the results with MySQLi.
When I press the update button, I want to come to a verification page to verify that it is correct.
What should I do?
I want to use this variable <? Php echo ($ Recordset1-> getColumnVal ("match_id")); ?>
pass that variable in a hidden form element, and use the hidden form element to return it.
Poj
How exactly do I do this? "and use the hidden form element to return it."
<input name="hiddenField2" type="hidden" id="hiddenField2" value="<?php echo($Recordset1->getColumnVal("match_id")); ?>" />
so the name of the form element is hiddenField2:
name="hiddenField2"
the code to return that value would be:
<?php echo(isset($_POST['hiddenField2'])?$_POST['hiddenField2']:""); ?>
assuming the form uses the post method, if it uses the GET method, change POST to GET
Poj
It does not work, I miss anything. What will it say on the Column Bindings tab?
Code/
if (isset($_POST["skicka"]) || isset($_POST["skicka_x"])) {
$UpdateQuery = new WA_MySQLi_Query($teamet_i);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "team_resultat";
$UpdateQuery->bindColumn("serie1", "i", "".((isset($_POST["serie1"]))?$_POST["serie1"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("serie2", "i", "".((isset($_POST["serie2"]))?$_POST["serie2"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("serie3", "i", "".((isset($_POST["serie3"]))?$_POST["serie3"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("serie4", "i", "".((isset($_POST["serie4"]))?$_POST["serie4"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("resultat", "i", "".((isset($_POST["resultat"]))?$_POST["resultat"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("serier", "i", "".((isset($_POST["serier"]))?$_POST["serier"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("banp", "i", "".((isset($_POST["banp"]))?$_POST["banp"]:"") ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("match_id", "i", "".((isset($_POST["hiddenField2"]))?$_POST["hiddenField2"]:"") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("id", "=", "i", "".((isset($_POST["hiddenField"]))?$_POST["hiddenField"]:"") ."");
$UpdateQuery->execute();
$UpdateGoTo = "kontroll_i.php";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
please send a copy of the page.
Poj
See private message
the code looks correct
Poj
The page is not online yet. only in my webserver at home.
I enclose check page where I want to see match_id along the bottom.
The post won't be available to that page, the POST is only available to the page that the form posts to.
you will need to use the recordset to lookup the match id value.
