ERROR: The ****** database does not exist. Please verify the database exists and the MySQL user (******) has the correct privileges to access it.
Thread begun 1/16/2015 3:14 am by mike-j-taylor318947 | Last modified 1/16/2015 6:15 am by Jason Byrnes | 1202 views | 1 replies |
mike-j-taylor318947
Cant get passed stage 3 of the instillation wizard, this is on the remote server not the testing server
everything in the connection file seems to be correct and the database does exist just wont conect
If the database does exist, then the error suggests that the user you are using to access it, does not have proper privileges to be able to access it.
you should contact your host to have them help you investigate the registered database users and elevate the privileges for the user you are trying to connect with.
