Error coming up after building search and results page
Thread begun 1/15/2015 9:44 pm by COHistorian | Last modified 1/16/2015 11:56 am by Jason Byrnes | 1771 views | 3 replies |
COHistorian
You have a tutorial to help with building a search and results page, but unfortunately, even after I follow all of the directions, I get the following error after testing a search...
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Name LIKE '%Pecchio%'))' at line 1"
My search field for this case is 'Name' as it is searching people. I should note that the search and results page are the same page, the search form is just at the very top. Do you have any suggestions? Thanks!
send a copy of the page please.
COHistorian
Attached is the page (labeled patients.php) and the files that are includes on the patients page. Let me know if you need anything else. Thanks
the problem is being caused by the naming convention you are using for columns in the table.
you should avoid using spaces in column names:
Patient Name
Either use the Camel Case naming convention:
PatientName
or use underscores in place of spaces:
Patient_Name
