browse server button
Thread begun 1/15/2015 11:50 am by mycalidesigns | Last modified 1/16/2015 6:17 am by Jason Byrnes | 3388 views | 7 replies |
mycalidesigns
I have this issue with a couple of my clients the Browse server Button not showing when you do the inline edit? please help.
mycalidesigns
check private message
see pm
mycalidesigns
sorry here you go
I updated the webassist/ckeditor/config.js file, i added:
config.filebrowserBrowseUrl  = "webassist/kfm/index.php?uicolor=eee&theme=webassist_v2&showsidebar=true&startup_folder=cms_files";
if (window.cms_root != null) config.filebrowserBrowseUrl = cms_root + "/" + config.filebrowserBrowseUrl;
in the CKEDITOR.editorConfig function.
I think you may have created this CMS System with an older version of Design Extender, this is fixed in the most recent version.
mycalidesigns
jason like always yours support is amazing!!!
P.S.
I have the latest, should i re-install to fix this issue?
Regardless of having the latest version installed, the CMS must have been created before you installed that version.
any new CMS Systems that you create should have that code in the configuration.js file already.
