Charges eCart
Thread begun 1/14/2015 11:58 pm by markdoyle87077 | Last modified 1/16/2015 11:53 am by Jason Byrnes | 3354 views | 11 replies |
markdoyle87077
Charges eCart
Just trying to redo an ASP cart into PHP. I am working on some charges. Could you confirm that the ASP rule that I have amended to PHP is indeed correct and will function as expected. The ASP cart name was dmbp and the the PHP is dmbc_in_stock
((WA_eCart_TotalColumn(dmbp, "TotalPrice") - (dmbp_GetDiscounts()) * 1) * Session("TaxRate"))
<?php echo (($dmbc_in_stock->TotalColumn("TotalPrice") - ($dmbc_in_stock->GetDiscounts()) *1) * $_SESSION["TaxRate"]); ?>
When I run a page to see if this works it displays 0.00 even when the cart is populated.
The rule is set to run when number of items in the cart > 0 and $_SESSION["TaxRate"] exists. I have set $_SESSION["TaxRate"] in the code to be 0.19 so the rule should return the TotalPrice * 0.19
use single quotes when creating a rule in the eCart object:
<?php echo (($dmbc_in_stock->TotalColumn('TotalPrice') - ($dmbc_in_stock->GetDiscounts()) *1) * $_SESSION['TaxRate']); ?>
markdoyle87077
Charges - eCart
I have pasted the amended rule but it still does not work. Everything parses okay. I have checked that the $_SESSION['TaxRate'] is being set:
// Set session variables
$_SESSION['TaxRate'] = 0.19;
echo 'Session TaxRate is '. $_SESSION['TaxRate'];
The code from the dmbc_in_stock_PHP.php is below
//eCart Rule
function WAEC_dmbc_in_stock_SalesTax() {
$totalCharge = 0;
if (true && ((sizeof($this->Items) > 0) && (isset($_SESSION['TaxRate'])))) {
$totalCharge += floatVal("".(($dmbc_in_stock->TotalColumn('TotalPrice') - ($dmbc_in_stock->GetDiscounts()) *1) * $_SESSION['TaxRate']) ."");//Result
return WA_eCart_FormatNumber($totalCharge, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
markdoyle87077
Charges - eCart
See private message
I see, the the cart object file, instead of referring to the cart object by name, it should be referred to as this.
i changed line 162:
$totalCharge += floatVal("".(($this->TotalColumn('TotalPrice') - ($this->GetDiscounts()) *1) * $_SESSION['TaxRate'])  ."");//Result
markdoyle87077
Charges - eCart
Hi Jason,
I changed the file locally and it still does not work. I also see that the www.dmballooncompany.com/set_up_cart.php does not display the sales tax even though you have changed line 162. Please advise.
it is showing the tax for me see screen shot.
markdoyle87077
Charges - eCart
Hi Jason,
Are you getting your result from www.dmballooncompany.com/set_up_cart.php because for me it simply does not work. I have now downloaded the files you changed to my local system to see if it works locally and it does not. I am hoping you ran the files locally your end and its simply a change of setting somewhere which will solve this issue.
Many thanks.
on the set_up_cart.php page, try changing the code order for the session and the get info call from:
$dmbc_in_stock->GetContent();
to having the getInfo() functor first:
