Can I use 'CSS Form Builder'with SQLi.
This post has been deleted.
If you are using the Form Builder in Data Bridge 1.2.1 then, yes it will be compatible with DW CC
the form validations errors are happening because you are trying to validate recordset values. Form Validations can be used to validate forms only not recordset values.
