Change jQuery tooltipd to spry
Thread begun 1/12/2015 4:13 pm by Hitaroo | Last modified 1/13/2015 6:14 am by Jason Byrnes | 888 views | 1 replies |
Hitaroo
Hi I am using Data Bridge (version: 1.2.1) > Database > Data Assist Pages to create insert and update pages the default tooltips are bubbles, which is different to the pervious version of Data Bridge.
Is there a way of globally applying my own tooltips without the bubbles, as in the older version?
Or is there a way of applying the jQuery tooltips globally?
Also which would you recommend going forward as I will be using Web Assist products?
Adobe have discontinued support for spry, that is why we changed to using jQuery and that is what we would suggest using going forward.
there is not a way to global change Spry to jQuery. You would need to manually strip the spry code from your existing pages, then add the jQuery validation.
