search results
Thread begun 1/12/2015 5:20 am by Jamie | Last modified 1/16/2015 8:48 am by Jason Byrnes | 5659 views | 15 replies |
Jamie
search results
Hi Jason
Am trying to set up a search facility which displays content based on db entriers.
In the db, I have columns set up (just using a couple here to show)
PortfolioWebsite
PortfolioEcommerce
PortfolioBranding
Each column is set to be either 0 or 1 ( 0 being 'disabled' and 1 being 'enabled')
What I am trying to do is when the user selects, for example, 'Branding' from the drop down the results page fetches only content that is set to 1 in the PortfolioBranding column, or if they selected 'Web Design' from the drop down, the results would fecthg only the content set to 1 from the
PortfolioWebsite column.
Have attached basic files that I have been playing with to this effect.
Cheers
Jamie
you won't be able to do this in DataAssist Search, you will need to configure the recordset for this.
the recordset details are a bit complex to describe here, contact me through Skype and I can walk you through it.
Jamie
thanks very much for your help and guidance on getting that RS set up.
Jamie
you're welcome.
Jamie
last question for this one, how do I get the drop down to display the selected <select>? http://www.motley.co.uk/portfolio.php
in design view, elect the select list, then in the property inspector, click the dynamic button. click the lightning bolt next to Select value equal to and select the binding for the select list.
Jamie
when I try that I get an error http://prntscr.com/5sf89f
have tried resetting the workspace, deleting the dw cache file
Try uninstalling the MySQLi server behaviors and installing it again, make sure you have the latest version.
Jamie
nope thats not worked. Uninstalled, reset and deleted cache, re-installed reset and deleted cache and tried again and getting same error
Seams to be a bug with MySQLi server behaviors setting a dynamic Select Value Equal to when all the values are static. I will log this as a bug, here is the updated select element code with the select value equal to change made:
<select name="PortfolioSearch" onchange="this.form.submit();" style="width: 380px; height: 40px; font-size: 18px; border: none; background-color: #E74E2E; color: #fff; padding-left: 10px;">
<option selected value="" <?php if (!(strcmp("", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Select A Service Section</option>
<option value="Webdesign" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Webdesign", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Webdesign</option>
<option value="eCommerce" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("eCommerce", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>eCommerce</option>
<option value="SEO" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("SEO", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>SEO</option>
<option value="Email" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Email", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Email</option>
<option value="Copywriting" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Copywriting", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Copywriting</option>
<option value="Social Media" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Social Media", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Social Media</option>
<option value="Branding" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Branding", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Branding</option>
<option value="Marketing Material" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Marketing Material", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Marketing Material</option>
<option value="Books and Magazines" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Books and Magazines", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Books and Magazines</option>
<option value="Vehicle Graphics and Signs" style="padding: 5px 0 5px 10px; border: none;" <?php if (!(strcmp("Vehicle Graphics and Signs", ((isset($_POST["PortfolioSearch"]))?$_POST["PortfolioSearch"]:"")))) {echo "selected=\"selected\"";} ?>>Vehicle Graphics and Signs</option>
</select>
