Universal Email Problem..
Thread began 1/11/2015 5:12 pm by anonymous | Last modified 1/12/2015 9:06 am by Jason Byrnes | 800 views | 1 replies |
anonymous
I have two separate instances of UE running on an ecommerce site. One is the order confirmation email which works correctly. The other is a user registration confirmation email which does not work. I checked the code for both and they should work. I ran a test and renamed the UE generated file that resides in /webassist/email/templates/ and with the order confirmation email it causes the checkout success page to hang however, when I run the same test with the other instance it has no effect ie. the page still loads. Any help would be greatly apreciated.
I have attached the relevant files.
Block_3.php
thankyou-trade-register.php
waue_thankyou-trade-register_1.php
add the following code just before the closing </body> tag to write the session contents.
<pre><?php var_dump($_SESSION); ?></pre>
the session contents will include a status of passing the email to the SMTP server and help in debuting.
one issue i can see already is that you have the to address and the from address set to the same. most SMTP servers will see that as spam and refuse to relay the email.
