Validation Show If - wiping the form field content?
Thread begun 1/08/2015 7:23 am by Nathon Jones Web Design | Last modified 1/08/2015 8:48 am by Jason Byrnes | 2552 views | 5 replies |
I've got Show If Validation on an input field and when it fails the validation it wipes the data entered in the field.
If you try this page:
http://www.doorsets.org.uk/apollodoors/contact-Apollo-Doors.php
..and enter "Joe Plumber 12345" in the name it will fail because I have set it to not allow numbers, But it wipes the Joe Plumber 12345 text and I want that text to remain to allow the user to correct the error.
Hope you can help. Thank you.
NJ
Use the form binding then instead of the validated entries binding group.
the validated entries binding group is set up to form values that pass validation, but not save entries that fail.
if you want to keep entries that fail, use the form binding group for the initial values of the form elements.
Form binding group? Where would I find that?
Thank you Jason.
NJ
EDIT: Do you mean adding this to each form field:
value="<?php echo((isset($_POST["FormInputName"]))?$_POST["FormInputName"]:"") ?>"
When I do that, it doesn't retain it, it replaces it with the placeholder text.
oh, right, the page refreshes when validation fails, so the post empty, sorry about that.
you could save the form to session variables, and use the sessions instead. a quick way to do that is to add the following code at line 1:
@session_start();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $key => $value) {
$_SESSION['savedform'][$key] = $value;
this will create a session away named saved form with an index for each form element that you can use in the value for the form instead of the post:
value="<?php echo((isset($_SESSION['savedform']['FormInputName']))?$_SESSION['savedform']['FormInputName']:"") ?>"
I'm not sure it refreshes, it just posts to the same page. I've implemented your suggestion though and it works great, thank you.
How would you advise I handle a successful form submission? I'd rather the form just disappeared and was replaced with a "thank you" message of some kind. Is that possible within the same page?
Thank you.
NJ
in whatever behavior you are using to process the form:
Universal Email if it sends an email, Insert record if it saves the data to a database etc...
you can specify a page to go to after it completes. set this to go to a thank you page.
