Problems with a second file upload field
Thread begun 1/08/2015 6:14 am by s.joiner74419001 | Last modified 1/12/2015 9:07 am by Jason Byrnes | 4497 views | 9 replies |
s.joiner74419001
In a Secure members area, I have a 'New Enquiry' form which has a 'File Upload Field' which is working fine. When the Member enters the enquiry their enquiry history. the same page has a form called 'Add Correspondence' which the member uses to add to an enquiry they previously made. this form also has an upload file field. I can not seem to get this second file upload to work. I have attached the two pages in question. The memo_new_enquiry.php page has the working upload file field. The enq_detail.php page has the one I can't get working! Am I missing something?
Thanks in advance
the forms encoding type is not set.
for file upload to work, the encoding type needs to be set to multipart/form-data
in the tag selector, select the form tag, then in the properties inspector, set the encoding type for the form tag to multipart/form-data
s.joiner74419001
I have such a short memory span sometimes !! Thanks Jason, completely forgot about that.
you're welcome.
s.joiner74419001
Jason, another problem I have is on the enq_detail page I want to hide the table structure for the correspondence post if there hasn't been one submitted. Currently if there hasn't it displays an empty table. I don't think I can use the 'If record is not empty' because the record set is using a left join with the enquiries table which always shows the enquiry. I have tried to use a 'show if' server behaviour but haven't been successful. Any pointers please!
Attached is the latest page!
if you echo the crspndnce.enquiry_id for a record where there is no correspondence, what is returned?
<?php echo($rowrsEnqDetails['crspndnce.enquiry_id']); ?>
i would think this would be 0?
s.joiner74419001
I kind of understand that :-/ .. But I still can't seem to configure the 'Show If' rule for it to work.
if the return value is 0 when there are no correspondence , the if statement would be:
<?php if($rowrsEnqDetails['crspndnce.enquiry_id'] > 0) { ?>
show table here
s.joiner74419001
I assume you mean setting the access rule as in the attached screen shot. This doesn't work, it just completely hides the div block what ever the result.
no, that is not what I mean
what i mean is using the if statement code i supplied around the table.
