Contact Form issue
Thread begun 1/07/2015 11:39 am by paulmgillard360368 | Last modified 1/08/2015 2:11 pm by Jason Byrnes | 5805 views | 16 replies |
paulmgillard360368
Contact Form issue
Hi Jason
I've been asked to add a couple of fields on the contact page for a site in the UK and wondered if you could help please?
(This is a private request - so the details are hidden).
Paul
glad to hear you have it working.
You should post any feature requests to our suggestion page, please:
http://www.webassist.com/community/feedback/dashboard.php
paulmgillard360368
...well almost :-)
I've replied privately to you Jason...
paulmgillard360368
Hand coding..
Hi Jason
If I hand code anything on the contact page, will the Wizard not work by trying to reset things, or will it absorb the hand edits and keep them?
Do hand edits break the use of the Wizard?
Regards
Paul
Hand edits don't necessarily break the wizard, but they will be overwritten if you then use the wizard to make other edits.
paulmgillard360368
Yup
Thanks Jason. That's what I thought might happen.
The page should redirect to a thank you page after sending the email.
edit the Universal Email behavior, and change the go to page to go to a thank you page.
paulmgillard360368
...not working just yet
Hi Jason
I added that email server behavior, but unfortunately it's not flagging up the Thanks! page just yet which I set as a GoTo page once the Submit button had been clicked.
?invalid=true means that the server validation is failing, the email won't get set if validation fails.
to determine which validation is failing edit:
PostResult($WAFV_Redirect,$WAFV_Errors,"contactus");
die($WAFV_Errors);
this will show a comma separated list of numbers indicating the failed validations. using that I can tell which validation is failing.
paulmgillard360368
feedback..
It comes up with: ,6
Does this tell you in which tabbed menu item there is a problem?
