jQuery Validation - losing transparency on error pop ups (Bloom.css)
Thread begun 1/07/2015 9:24 am by iain331081 | Last modified 1/07/2015 11:21 am by Jason Byrnes | 2723 views | 5 replies |
iain331081
I'm just adding some jQuery validation, which is all working nicely.
I just have some of the pop ups over some other text, so would like to lose the semi transparency. I'm looking in the Bloom.css file, but can't see anything obvious. (Other than the references to 'transparent' in the .Bloom-before and .Bloom-after rules, which are controlling the little pointer triangle.)
Am I looking in the right place, or is it in some JS somewhere else?
Thanks.
please post a link where i can see the problem to troubleshoot.
iain331081
Thanks Jason - see below.
in the .Bloom_Wrapper selector remove:
opacity: 0.8;
and in the .Bloom selector, remove:
background-image:-webkit-gradient(linear, 0 0, 0 100%, from(#990000), to(#990000));
background-image:-webkit-linear-gradient(top, #990000, #990000); /* For Chrome and Safari */
background-image:-moz-linear-gradient(top, #990000, #990000); /* For old Fx (3.6 to 15) */
background-image:-ms-linear-gradient(top, #990000, #990000); /* For pre-releases of IE 10*/
background-image:-o-linear-gradient(top, #990000, #990000); /* For old Opera (11.1 to 12.0) */
background-image:linear-gradient(to bottom, #990000, #990000); /* Standard syntax; must be last */
iain331081
Thanks Jason - I'd tried removing those lines, but managed to miss the opacity value.
you're welcome.
