How do I only tax NYS 8.875 percent via ECart?
Thread begun 1/07/2015 9:15 am by sfranzken73972 | Last modified 1/07/2015 9:48 am by Jason Byrnes | 846 views | 1 replies |
sfranzken73972
Which rule do I use and how would I configure that?
Thanks WA
When you run the checkout wizard you can set the tax rule on the tax tab, you can select a state to apply to, and add the percentage, that is the simplest way to add it in.
