Add to cart not working
Thread begun 1/06/2015 3:24 pm by rgolab68503 | Last modified 1/07/2015 12:28 pm by Jason Byrnes | 2328 views | 5 replies |
rgolab68503
Hey there,
Things were rolling along pretty good until i added a cart to our new support site. I've tried checking what it could be from previous posts but am not having much luck.
Basically I go to a product and hit the add to cart button and it hangs on the please wait message. I tried adding an error code and removing the Redirect with no luck as well.
error_reporting(E_ALL);
I did have some initial errors where the pages were placed into the root folder rather than the product catalogue folder I pointed them to. Not sure if this made a difference but I basically started from the beginning again. Could it have something to do with the name? It's looking for 'toyocart1_1_ID_Add" so it's looking for 1_1 because of the changes I made but can't find it?
Could you have a look and let me know if you can see what is going on or let me know what other information you need?
Thanks for any help.
looks like the progress bar is causing an error.
try removing the following code:
WADFP_SetProgressToForm('Details_Compact_Default', 'Details_Compact_Default_ProgressMessageWrapper', WADFP_Theme_Options['SmallSpin:Slate']);
</script>
rgolfer
Hi Jason,
That got me to the next step thanks a bunch. The process is small so I could probably live without the progress bar or should I fix it somehow?
Have a great day.
The add to cart is not intended to be used on a page that includes admin features like update and delete, that's the heart of the problem. there really is not another fix accept to remove the progress bar.
rgolfer
That makes sense I'll just leave it out.. Thanks again for your help.
you're welcome.
