Cutom Toolbar and Edit Source Toolbar
Thread begun 1/06/2015 2:54 pm by Lee Firth | Last modified 1/09/2015 8:45 am by Jason Byrnes | 2286 views | 5 replies |
Lee Firth
Custom Toolbar and Edit Source Toolbar
I have created a custom toolbar and set the values for "Admin Toolbar" and "Inline Toolbar" to use it. The problem I have is that if you click on "Edit Source" in the inline editor, the resultant popup window uses a full toolbar not the custom one I have created. I can't seem to find where this toolbar is set.
Lee Firth
See PM
Ok, that is controlled in WA_CMS.js on line 205:
toolbar: pcms_toolbars["full"],
it is set to 'full', but you can change it to use a different toolbar manually.
Lee Firth
Thanks Jason, that did the trick.
you're welcome.
