Data Search
Thread begun 8/27/2009 7:54 am by mike292921 | Last modified 9/03/2009 6:00 am by mike292921 | 4660 views | 5 replies |
mike292921
Data Search
Problem I am having is that I have 2 columns in a database one for item name and one for item description. I used advance search to look up the text and is set on (and) separator what my problem is that when I type text as a whole since it is searching 2 columns it won't exactly find that item. For instance.
when I type Item Name Item Description in the form it automatically searches Item Name Only and not the 2 of them as a whole. Could have been something I did, I am still too new. I would like to know if I can .
Right now its searching one column or another but can they be combined?
What would be the best way to go at this.
You should only be using the 'AND' and 'OR' separators to differentiate between the different criteria. It sounds like you have a single criterion, to do a like search with a single field on multiple columns. To do this you would just make sure that you have both columns selected. This way it will do the search on both columns regardless and return results where there were matches. So if the user enters something for an item that is either part of the name or part of the description that record will be returned in the results.
mike292921
Thank You Eric, I still need some help
When I used the datassist search wizard I selected the columns I would like to search correctly. I have been messing with it to sort it out properly but I am fairly new, it is most likely something I am missing.
First I have the recordset set to select the columns only is that correct?
Then I used the search wizard and I selected out of the column for the Itemname and Itemshortdescription to be chosen I highlighted the both here is what I have as a search parameter.
1. Type 2.Selector 3.Column 4. CT 5. Comparison 6. Value
1. Key 2. AND 3. Itemname, Itemshortdescription 4.T 5. Includes (although I had it previously set to begins with) 6. Post form (which works)
The problem is that when I search items I want it so that it will look up that item exactly that meets both criteria otherwise don't show other products that aren't related. Tell me what I can do to achieve this.
I appreciate all your help and products.
mike292921
Just keeping this fresh
Can anyone help me?
So when you want to limit the information based on multiple criteria you should get the criteria setup and make sure that the separator is set to AND.
For example in your current search you have both columns selected. This means that if you enter a value that is found partly or fully in either of these columns all records that have a match will be returned.
To make it more limiting you should break this into multiple criteria. They will be almost exactly like each other but the search separator of AND between them will ensure that it is found in both and only where it is found in both will the matching record be returned. If you would like to do an exact match type search then you should set it up that way instead of the keyword includes type search.
mike292921
Thank again Eric
I will try this today.
