Since I created user validation for some pages my login.php will not show on my site.
Thread begun 1/05/2015 10:22 am by bbgd | Last modified 1/06/2015 1:36 pm by Jason Byrnes | 7562 views | 15 replies |
bbgd
The page login php shows up fine on my test server. If I go to a restricted page on the test server it automatically goes to the login page. If I click on CLIENT LOGIN it also takes me to the login page. When I upload it to my server the page is blank no matter which way I go. I also can't get the passwords to work but I can get the redirect.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
bbgd
The error I get is:
Warning: mysql_pconnect(): Access denied for user 'boydbartley'@'localhost' (using password: YES) in /home/cinder2bob/public_html/test2/Connections/Interprimus.php on line 9
Fatal error: Access denied for user 'boydbartley'@'localhost' (using password: YES) in /home/cinder2bob/public_html/test2/Connections/Interprimus.php on line 9
Line 9 is @session_start();
That suggests that the database connection file is not updated with the correct information for connecting to the remote MySQL server.
bbgd
That suggestion worked. Thanks.
bbgd
See private message
What are the pages you are having trouble with? Please provide direct links.
you say it's not accepting password?
please give step by step details to reproduce the issues so i can troubleshoot.
bbgd
http://test2.interprimus.com/login.php- all restricted pages go here. See private message for passwords. When I put in the the username and password I get the 'Invalid username or password' message.
http://test2.interprimus.com/contactPage.php- I click on the login button and get the following message:
Warning: require_once(Connections/interprimus.php): failed to open stream: No such file or directory in /home/cinder2bob/public_html/test2/contactPage.php on line 11
Fatal error: require_once(): Failed opening required 'Connections/interprimus.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/cinder2bob/public_html/test2/contactPage.php on line 11
Will you need my password for the phpMyAdmin?
Login page- there where duplicate sections of code, looks like you ran the security assist wizard multiple times to cause the duplicates. i removed the duplicate code.
also one of the validations was set to enforce a 6 character minimum on the user name, this was failing because the user name you are using is not 6 characters long.
Contact page: The connection was pointing to Connections/interprimus.php, but the connection file is named with an uper case I, i updated that to:
to fix the error.
the other errors that are on the page are a a result of your mail script.
in the ScriptLibrary/incSmartMailer.php file, you should change line 7:
session_start();
@session_start();
also for the form element value, you should use isset, for example:
value="<?php echo $_POST['first_name']; ?>"
should be:
value="<?php echo(isset($_POST['first_name'])?$_POST['first_name']:""); ?>"
