math script
Thread begun 1/05/2015 7:34 am by Jamie | Last modified 1/06/2015 1:49 am by Jamie | 2439 views | 4 replies |
Jamie
math script
Hi Jason
Just some advice if I may please.
I have a client that is looking to be able to allow their visitors to make a few selections (dynamically driven from the db) which will be numbers and then have a script calculate those values to create a total.
I have been hunting for a tut online but cant find one and am thinking that my search terms may not be quite right as am not 100% sure what I should be looking for so just wondering if you might know of a script / tut that you could point me in the direction of?
Many thanks
Jamie
theres not really a script that will do this for you, you need to write the code to do the math on the returned values.
for example, if the values are coming from a recordset:
<?php echo("The Total Is: ".($row_RecordsetName['column1'] + $row_RecordsetName['column2']).""); ?>
Jamie
oh right so where should i start if elements are variable depending on the option selected?
when the form submits, you could do math on the posted values:
<?php echo("The Total Is: ".($_POST['element1'] + $_POST['element2']).""); ?>
Jamie
Thanks Jason
I will give that a shot
Cheers
Jamie
