Search not filtering after I add additional "Where" clause in the recordset
Thread begun 1/04/2015 8:10 pm by Blikbrein | Last modified 1/07/2015 10:36 am by Jason Byrnes | 3495 views | 6 replies |
Blikbrein
I have a page with payments and charges that is filtered by begin date and end date. I do not want to show any zero values in the filtered report and therefor I have added a Where in the recordset:
WHERE PaymentDebit > 0 OR PaymentCredit > 0
Without the 'OR PaymentCredit > 0' Date filtering works but after adding it all records are shown and there is no filtering.
I've attached the page for you to inspect. The result must be that records are filtered according to begin and end date and that items with a 0 in PaymentDebit AND 0 in PaymentCredit should not be shown which would be a 0 value record.
change the OR:
to use AND instead:
WHERE PaymentDebit > 0 AND PaymentCredit > 0
Blikbrein
Thanks but in this case OR is needed since all debits have 0 credit values and all Credits have 0 debit values which means every entry will have either a 0 in the debit field or a 0 in the credit field. No record wil have a debit AND credit > 0. This needs to be OR, but as I said the Search behaviour then shows all the records in the query instead of filtering them.
The recordset code is duplicated.
change lines 135 - 164:
$maxRows_WADAPayments = 1000;
$pageNum_WADAPayments = 0;
if (isset($_GET['pageNum_WADAPayments'])) {
$pageNum_WADAPayments = $_GET['pageNum_WADAPayments'];
$startRow_WADAPayments = $pageNum_WADAPayments * $maxRows_WADAPayments;
mysql_select_db($database_anna, $anna);
$query_WADAPayments = "SELECT PaymentsID, `Users`.`UserFirstName` AS Users_UserFirstName, Users.UserSurname, `ContractTracking`.`PackageID` AS ContractTracking_PackageID, PaymentDate, PaymentDocno, PaymentDebit, PaymentCredit FROM Payments LEFT JOIN Users ON Users.UserID = Payments.PaymentClientID LEFT JOIN ContractTracking ON ContractTracking.ContractID = Payments.PaymentContractTrackingID WHERE PaymentDebit > 0 OR PaymentCredit > 0 ORDER BY Users.UserSurname ASC, `Users`.`UserFirstName` ASC, PaymentDate ASC";
setQueryBuilderSource($query_WADAPayments,$WADbSearch1,false);
$query_limit_WADAPayments = sprintf("%s LIMIT %d, %d", $query_WADAPayments, $startRow_WADAPayments, $maxRows_WADAPayments);
$WADAPayments = mysql_query($query_limit_WADAPayments, $anna) or die(mysql_error());
$row_WADAPayments = mysql_fetch_assoc($WADAPayments);
if (isset($_GET['totalRows_WADAPayments'])) {
$totalRows_WADAPayments = $_GET['totalRows_WADAPayments'];
} else {
$all_WADAPayments = mysql_query($query_WADAPayments, $anna);
$totalRows_WADAPayments = mysql_num_rows($all_WADAPayments);
$totalPages_WADAPayments = ceil($totalRows_WADAPayments/$maxRows_WADAPayments)-1;
$query_WADATotals = "SELECT SUM(PaymentDebit) AS Debits, SUM(PaymentCredit) AS Credits, SUM(PaymentDebit) - SUM(PaymentCredit) as Balance FROM Payments LEFT JOIN Users ON Users.UserID = Payments.PaymentClientID LEFT JOIN ContractTracking ON ContractTracking.ContractID = Payments.PaymentContractTrackingID";
setQueryBuilderSource($query_WADATotals,$WADbSearch2,false);
$WADATotals = mysql_query($query_WADATotals, $anna) or die(mysql_error());
$row_WADATotals = mysql_fetch_assoc($WADATotals);
$totalRows_WADATotals = mysql_num_rows($WADATotals);
} else {
NOTE: the recordset criteria you mention is contrary to what you originally wrote, that is the basis for the confusion.
that is why I suggested using AND.
Blikbrein
Ok, thanks. Apologies for the misunderstanding. Why does the recordset sometimes duplicate? Normally I see this and delete the duplication, but this time I missed it. I think it happens with complex queries...?
Will let you know if it worked after I deleted and retried.
Blikbrein
Tried it and still get all the records instead of filtered results... I attached the changed file for you to look at again. Thanks
