Click counter on dynamic images
Thread begun 1/03/2015 3:02 am by info4753 | Last modified 1/13/2015 6:12 am by Jason Byrnes | 2265 views | 3 replies |
info4753
I want to count the clicks that users do on images on my homepage. The images come out of a database table and the count should happen on the homepage itself. I managed to implement an update behavior but it updates all click within the click count field of the first recordset in the database.
So the form knows that an image has been clicked but not which one. The values for the corresponding key seems to be wrong. I'm currently using <?php echo $row_rsPromotionen['PROMID']; ?> means the value from the repeated recordset of the images. But it looks like that it's not working like this.
Repeated form:
<form method="post" name="FormPromotions" >
<?php do { ?>
<div class="container-promotion"> <a href="<?php echo $row_rsPromotionen['LinkToURL']; ?>"><input type="image" name="<?php echo $row_rsPromotionen['PROMID']; ?>" id="<?php echo $row_rsPromotionen['PROMID']; ?>" src="<?php echo $row_rsPromotionen['PromotionBanner']; ?>" width="775" height="225" alt="<?php echo $row_rsPromotionen['Promotion']; ?>" title="<?php echo $row_rsPromotionen['Promotion']; ?>"/></a></div>
<?php } while ($row_rsPromotionen = mysql_fetch_assoc($rsPromotionen)); ?>
</form>
Update code:
// WA DataAssist Update
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection = $ullrich_db;
$WA_table = "promotionen";
$WA_redirectURL = "".$row_rsPromotionen['LinkToURL'] ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "PROMID";
$WA_fieldNamesStr = "Clicks";
$WA_fieldValuesStr = "".$row_rsPromotionen['Clicks']+1 ."";
$WA_columnTypesStr = "none,none,NULL";
$WA_comparisonStr = "=";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_where_fieldValuesStr = "".$row_rsPromotionen['PROMID'] ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode($WA_AB_Split, $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_ullrich_db;
@session_start();
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
Thanks for any help on this.
in the anchor link add a url variable to pass the image ID, for example:
<a href="<?php echo $row_rsPromotionen['LinkToURL']; ?>?id="<?php echo $row_rsPromotionen['PROMID']; ?>">
in this example the image is passed as a GET variable named id
now open the binding panel, click the plus button and Select URL Variable, name the new variable id. this creates a binding for the id variable in the link.
in the update record behavior, set thew ID field to the PROMID column in your table, and bind the ID value to the id url binding you created.
info4753
Thanks Jason. Didn't know that this problem can be solved like this. I found a solution with a redirect page and an update before page loads, but your solution seems to be easier.
you're welcome.
