Detail about Categories & SubCategories
Thread begun 12/30/2014 12:18 pm by Kumel | Last modified 2/05/2015 12:46 am by Ray Borduin | 2094 views | 5 replies |
Kumel
I want to know few details about how Cat & SubCat works.
Lets say for instance i got 3 products: x, y & z.
3 Cat: a, b & c
3 SubCat: 1, 2 & 3.
Moving along with above example.
Cat 'a' has two SubCat '1 & 3'
Cat 'b' has two SubCat '2 & 3'
Cat 'c' has three SubCat '1, 2 & 3'
Each product has Cat & SubCat.
I know how to display all Cat using repeat region but not with SubCat
Expected result, Example below:
<li><a href="#">a</a>
<ul>
<li><a href="#">1</a></li>
<li><a href="#">3 </a></li>
</ul>
</li>
<li><a href="#">b </a>
<ul>
<li><a href="#">2</a></li>
</ul>
</li>
<li><a href="#">c </a>
<ul>
</ul>
</li>
DB structure: Screenshot attached.
Regards
You could create a category results page and a separate subcategory results page... filter the subcategory results with a url parameter that is the category ID from the first category table.
Then use an include to include a new copy of the subcategory results after each category result... or if you are only showing one category per page then you could add it in with framework builder using a plugin.
Kumel
Is there any tutorial on this?
No, there is not a tutorial for this.
Kumel
i created results page Also used filter on subcatresult page.
how do we do this: Then use an include to include a new copy of the subcategory results after each category result... or if you are only showing one category per page then you could add it in with framework builder using a plugin.
My page is all products page.
where all products are displayed.
i have categories displayed from productcategories table.
I wanna show subcategories as well.
so what next step?
Kumel
well i guess i got it now :)
thanks a lot. went through a tutorial on nested rs.
http://www.webassist.com/tutorials/Display-nested-recordsets
Regards
