Record Count
Thread begun 12/30/2014 6:21 am by Mushroom-Graphics | Last modified 12/30/2014 2:22 pm by Ray Borduin | 2374 views | 4 replies |
Mushroom-Graphics
Record Count
I am trying to add a record count to a results page for Manufacturers. If a Manufacturer has say 20 products on the site I want to display "20 products" in a TD in their row. Is there a tutorial I can use? I have downloaded MySQLi
If you have a recordset with products on the page then the record count will be available from the bindings. If you want to get a count without showing the results you can do that with SQL. Just create a recordset like:
SELECT Count(*) AS ProductCount FROM ProductsTable WHERE manufacturer = 'the manufacturer'
Then you can display the ProductCount field from that recordset
Mushroom-Graphics
Still having a little difficulty. I can not seem to get the count to reflect the rows they are in. I am attaching the page.
Put it all into one recordset so that you get a new count for each row like:
SELECT man_id, man_code, man_name, updated, (SELECT Count(*) FROM pmap WHERE pmap.mc = man_code) AS ProductCount FROM manufacturers ORDER BY man_name ASC
Mushroom-Graphics
I keep getting a SQL error in DW but it works. Cool thanks
