pop up dialogues not working properly
Thread begun 12/29/2014 1:28 pm by Jamie | Last modified 1/18/2015 10:52 am by Jamie | 4315 views | 8 replies |
Jamie
Hey Ray and Jason
Hope you both had a great Christmas?
Just wondering on something as I have just invested in ms surface running win 8.1 and in all the pop up dialogues look similar to the 2 I have attached....not sure what I need to do to adjust to accommodate?
Cheers
Jamie
Turn off "Large Fonts"... it appears that is throwing off the interface.
Jamie
am assuming you mean in win 8.1 rather than dw?
I have been trying to get this to work...marginal improvement in the rs window but no joy in the repeat region side of things
Yes it is a windows setting... looks like it is still larger than default. I'm not sure where that is controlled in 8.1.
If you want to set up a connect meeting, contact me via Skype and I'll look into it with you.
Jamie
cheers Ray
have managed to sort it out (found this article if anyone needs the reference https://mcmw.abilitynet.org.uk/making-text-larger-windows-8-1/ )
makes dw v small :(
Jamie
Hey Ray
Just wondering if you might have plans to allow the popups to accommodate the usage of larger fonts etc? I can only set it to 125% without the problem happening but this is too small in other areas/programmes
cheers and have a wonderful 2015!
Jamie
We may be able to update our interfaces to ignore larger fonts. We can't really update them to allow for the font size to change since Dreamweaver interfaces require a specified width and height.
If you want to contact me via skype tomorrow or the day after I'll investigate it with you and see if there is an easy solution.
Jamie
Happy New Year Ray
Thanks for the offer. Will take you up on that and get in touch once the 'celebrations' have all died down!!!
Jamie
if anyone else is experiencing this issue, have managed to find a fix for this here http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
works well with the scaling issue
