Problem with dataassist not working after adding new Rs
Thread begun 12/29/2014 11:55 am by Kumel | Last modified 2/27/2015 12:22 pm by Jason Byrnes | 9893 views | 51 replies |
Kumel
Ok i had created dataassist pages.
So i need link to have its own url so had changed some settings from this post as discussed:
http://www.webassist.com/forums/posts.php?pid=185247
Now after that things added.
I m stuck at a problem.
I have a product detail page. All seems fine.
Permalink is used & etc.
Now when i add a new RS then problem seems to appear. Must be a problem with codes.
Please can you take a look at it.?
For instance currently all product details are visible on product details page
But as i add another RS for subcat then i don't get an error but all product details are not shown. no error as well.
Before adding new RS:
$colname_ProductsPerm = "-1";
if (isset($_GET['perm'])) {
$colname_ProductsPerm = $_GET['perm'];
$colname_Products = "-1";
if (isset($_GET['ProductID'])) {
$colname_Products = $_GET['ProductID'];
mysql_select_db($database_con, $con);
$query_Products = sprintf("SELECT * FROM Products WHERE ProductID = %s OR ProductLink = %s", GetSQLValueString($colname_Products, "int"), GetSQLValueString($colname_ProductsPerm, "text"));
$Products = mysql_query($query_Products, $con) or die(mysql_error());
$row_Products = mysql_fetch_assoc($Products);
$totalRows_Products = mysql_num_rows($Products);
After Adding new Rs:
$colname_Products = $_GET['perm'];
$query_Products = sprintf("SELECT * FROM Products WHERE ProductID = %s OR ProductLink = %s", GetSQLValueString($colname_Products, "text"),GetSQLValueString($colname_Products, "text"));
$query_Recordset1 = "SELECT * FROM subcategories";
$Recordset1 = mysql_query($query_Recordset1, $con) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
before.php and after.php attached.
before.php is only about product details.
without any subcat involved.
after.php is after adding subcat RS . simple RS
after adding New Rs i also replaced from this:
to this:
Yet no result showing up.
Why did you change the parameter code? I'm pretty sure you shouldn't be updating that.
What exactly stops working once you add the new recordset? I'm a bit confused.
Kumel
no results are shown. just blank. Page is visible.
Before after screenshot attached.
Likas papaya soap is product name from product's table & then there is productdesc
but as i added new Rs nothing is shown. just blank.
I might have mess around with codes in parameter code cos it wasn't working so was cross checking & changing some codes.
Change the parameter code back... that would definitely break it. If you still have issues, please post the url and ftp information in the private area and I'll take a look.
Kumel
That link doesn't have a page name... and that ftp information takes me to an empty directory.
Kumel
product-details.php (product page)
Products_Results.php all result page
Kumel
when clicking product_result takes you to product_detail page but isnt working.
base url should be?
Please check the FTP information and make sure that user has access to the root directory. I can't seem to get in with that FTP info. I'll initiate Skype contact if necessary, but I'd like to debug the files first.
Kumel
sorry. some minor change.
Now works fine.
