Cannot sign in to load more photos. This happened last month and was fixed. I now get the following fatal error message: Fatal error: Call to undefined function curl_init() in E:\domains\s\shamblescc.co.uk\user\htdocs\powerGallery\admin_gallery\image
Thread begun 12/22/2014 4:44 am by mail369795 | Last modified 1/13/2015 7:02 am by Jason Byrnes | 2854 views | 3 replies |
mail369795
Cannot sign in to load more photos. This happened last month and was fixed. I now get the following fatal error message: Fatal error: Call to undefined function curl_init() in E:\domains\s\shamblescc.co.uk\user\htdocs\powerGallery\admin_gallery\images\inst
Pressed index.php (blank page) then f12 which then says "Fatal error: Call to undefined function curl_init() in E:\domains\s\shamblescc.co.uk\user\htdocs\powerGallery\admin_gallery\images\installed.png on line 3
This error means that the cURL library is not loaded on the php server. Most likely the host did an update to PHP recently and in the new update, they did not enable the cURL library.
You will need to contact the host to have then enable cURL on the server.
mail369795
I contacted my Host and cURL is enabled, as you can see below.
PHP 5.4.32
PHP 5.4.32 is installed.
cURL
cURL [7.36.0] is installed.
GD Image Library
GD Image Library [bundled (2.1.0 compatible)] is installed.
File Permissions
Files and directories can be created.
SimpleXML
SimpleXML is installed.
Session Management
Session management works as expected.
I then tried to get into power gallery to be faced with: 500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
So then I tried to reload power gallery and go through the wizard, but get stuck at the Data base information, I get the following.
ERROR: Could not connect to MySQL. Please verify the server, username, and password are correct. ( I have contacted my host and they confirm the info I put in is correct) even the video tutorial does not work.
I do not seem to be getting very far here, just spending a lot of time getting nowhere. Any more suggestions?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
